hi guys i’ve created an object in tinkercad and when i trying to print it the print stop extruding at 26 % or 50 % it always happens to me when i use tinkercad or i the object is non manifold error here are the object that i’ve created
thanks
ingenious_wluff-maimu(1).stl (37 KB)
ingenious_wluff-maimu.stl (20.4 KB)
Perry_1
Neither of these models have non-manifold errors, and slice properly.
Can you provide additional information. Are these two objects slicing properly in your slicer, but then failing when you print them?
What printer and software are you using?
Can you provide additional information as to what the failure looks like, what your printer is doing when it fails, etc.?
Magesh
Please upload the files to netfabb (Microsoft) and then follow the steps there to fix the 3D model. Once it’s fixed, you can download and print it.this should fix the problem.
Perry_1
To be more clear: I have tested both of these models, they are fine, and do not have non-manifold issues. Both slice fine.
The problem is something else, and we need more information to help.
