This is the end result of the Printtable build used in the instructables
Thats nuts! You can make a 3D Printer out of ANYTHING these days! I did a blog post at epic3dstuff.com 2 if you want to check it out
Congratulations! You are pushing the 3D printing industry to a whole new level!
Hi. About your instructable (I don’t have an account) that I was confused about and others may be too, for the printed parts:
Is a single print of every stl file except, 4 of the RodSupport and 2 of the XAxisSet.stl correct?
That covers all pieces on the Parts Required image except:
- The U-shape: mid-row, column 4
- The square-frame: bottom-right corner
Are these pieces required?
Thank you
*Also, if you happened to have printed yours with ABS, what infill% worked well?
**When were you planning to have the parts on your site available, it may be faster to just order them from you if you will have them this week.
Hi
you are correct the u shape is not required and not included in the STL download.(it is from a variation design)
the he square is the trim cover which goes over and around the TFT. I forgot to add.
parts will be available to purchase from the website in the next 5days
all Printtable parts was done in PLA
hope this helps
thanks
wayne
