Jun 2016
It is not the second issue that you mentioned, but I wasn’t aware of the first one with the magnet. I fear that there is an issue with the motor. The 3D printer is in a school so the chance of it being hit is probably close to 100%.
I don’t think this is the issue because the filament moves back and forth manually with no issues and when I pull the filament out I don’t see any abrasions on it. It flows nicely when I manually push it.
20 days later
Have you fixed this issue yet? If not try tightening the tensioning screw I have mine much tighter than that with good results. You can also try increasing the current of the extruder motor through the M565 command. Let me know if this helps.
Sinscerely,
Alexander Sainz
Alexander’s Hub
1 year later
Hello. I’m experiencing the same issues. I didn’t see a resolution on this thread. Can you share the outcome? Thanks.
