Jul 2016
Hi everybody,
I need 3D printed details for a low-volume product. I would need around 50 pcs/year.
I have tested a lot of printers, especially printers that is said in tests to have good quality such as Ultimaker 2+, but I have not found anything that is OK yet.
The thing I need is a small case for electronics with windows for LEDs. Ideal would be a 2-material print with the LED window in transparent material. But I would be happy with a single material with holes where I put in LED windows. I would prefer to not do any surface treatment on each piece.
The material should be something that will last for many years. I have used ABS in most prints. I feel uncertain about PLA, but there may be other materials that will work.
What I want is reasonably regular surfaces. It doesn’t matter if the layers are visible as long as there is no big variation X/Y from layer to layer. But it seems that if there is a disturbance in a layer such as a hole, this will cause things to happen all around that layer.
I suspect that this has to do both with the slicer and the position accuracy. I am attaching pictures of a 2 material print with LEDs, same with the LEDs out and one with 1 material. The black is ABS in all photos.
It would be very nice with some suggestions about hub and/or printer and/or material.
Best regards
Kurt Mirdell
    Jul '16
    Jul '16
  • 18
  • 1.9k
  • 10
Hi Kurt, you really should be able to find better quality than the items in the photos with something like an Ultimaker 2+ or many other printers. Do you know what settings were used for these examples? I’ve printed several items with holes with a precise required dimension and they’ve been spot on.
One other tip would be to print onto glass as this will give the bottom layer a nice glossy smooth finish which looks great for the control surface of a device.
Those are simply not good prints. This is a result of several things, including the fact that they are just not good prints.
Since printers is an ambigous term, I will refer to Persons and Machines…
If the person is not good with ABS settings and such, this will be the result. The ABS is shrinking differently when the layer with the holes is being printed, than not, and that is why you are getting the warping in that area. A good person will not produce prints that look like that.
The issue is not that most machines print layers differently when there are holes, the issue is the person setting up the print is not doing a good job, or the machine they are using is not good at printing. But a person who knows how to handle ABS and has a good machine will give you a better print.
Next, consider PLA. Yes, theoretically, ABS holds up better than PLA in heat (a slight difference), and works better when the item has a hinge, because ABS can take a few more bends than PLA, and ABS cannot be shock broken as easy.
But the differences are so minimal, that I would advise you to directly go to PLA. ABS is a material designed for extrusion molding, so it is specifically designed to shrink from the mold. As such, it is more prone to warping and shrinkage while being printed. PLA crystalizes as it cools, and as such, is more exact to the original digital model. For an electronics case, PLA is often a more perfect material, and unless this is an item that will be in an automobile, or direct sunlight, or has a hinge, or is going onto a quadcopter, I would recommend PLA for a perfect, durable, long term item that prints without shrinkage or warpage.
That being said, I would still suggest that the ABS print you are showing was done poorly, even an ABS print should be better than that, by alot. It is simply a poor print. (even so, I would still recommend PLA)
Finally, I can’t be sure how large the print is by the pictures, but it looks extremely small. As such, it seems to me if you need 50 in a year, 3d printing is a good option. I can print small parts inexpensively, as I have some printers with several print heads that can print at once. Or, if you want to print in small batches as you go, such as when orders come in, than 3d printing is a great solution. Also, if you see yourself making changes as you go, 3d printing is a great solution. But just as an FYI, if you know you will be using 500, then you want to go with extrusion molding.
If you want to discuss this further, or if you want to share your model with me so I can advise you further, contact me https://www.3dhubs.com/cleveland/hubs/perry. You can upload the model for a quote or just start an enquiry.
The dimension are is 29 x 13 x 23.6 mm. Layer height is 0.1 mm.
Some times it’s good to use resin casting for small volume.
Make a best finish on one model, create silicone mold and cast black resin with same finish over and over.
Check https://www.smooth-on.com/ 3, they have all you need and for finishing 3D printed parts to.
Hello. Have you considered SLA over FDM printing? The FormLabs printer I use can go down to 25 microns in resolution. The prints will look much better than the examples in your photos. It cannot do multiple materials in the same run. However, (as someone else suggested) if you print the lens for each LED as a snap-in piece, they will look much better. In clear, the SLA prints from the FormLab can be polished very clear (of left frosty for a more diffused lighting effect). I’d be happy to quote you on an example if you like. When you look at my hub, you will see examples of some really small items with incredible detail. Have a great day. Todd.
https://www.3dhubs.com/concord/hubs/3dmatters2us 2
I Agree the quality of the prints in the photos are simply poor even for an Ultimaker 2. The printer I use produces really nice smooth prints from the off, One thing though, you will not get great transparency using translucent filament, I don’t think it will allow enough light through for the LEDs- I see that it appears you have 3D printed the LED windows in place. You will get a better finish by sticking with one material, I suspect the disturbance may be caused by the led window material you have introduced (as it may not be the same as the body - Let me know If that is the case)
I can also print these for you if your interested - drop me a quote see https://www.3dhubs.com/oxford/hubs/thomas 1
What size is your enclosure? Is there any IP ratings required for the enclosure? (Dust/Water ingress?) What is the expected lifespan for the product? and does it need to be rugged? - These questions help to determine the material requirements - If a certain amount of ruggedness is required - go with ABS, After all its an industry standard material for Electronic enclosures.
Hope that helps?
Tom
Hello Kurt!
The print quality in the attached pictures looks quite bad for most printers, especially ultimakers and such.
I would say that your best, and simplest option, would be to find someone who can print your part from PETG, since that material doesn’t have the same issues with shrinking as ABS does. As for the windows, the best way would probably be to laser-cut them in truled plexi which would diffuse the light so that the whole window light up equally instead of having a dot in the center.
I’m based in stockholm to, so if you are interested, contact me on my hub (https://www.3dhubs.com/stockholm/hubs/svensson-d-sign 2) and I’ll print a sample and cut some plexiglass for you.
Best regards
Oscar Svensson
9 days later
Hi Kurt,
my 3D shop at Sveavägen in Stockholm can help you. We are working with solid blocks of real materials, like aluminium, wood and platsics, to make end products in small runs. And if you need prototypes, we make those with FDM 3D printing.
Give me a shout via my Hub if you are interested!
Best
/Lamin
