I am looking for someone who can 3D print a flexible spring in materials type PET or Innoflex 60(from Innofil3D), or any other material that can be used to make functional prototypes of springs.
do you concider Colorfabb’s XT for the spring ? XT is a Polyester and PET is just a special kind of Polyester, so this could work.
Otherwise i could also offer prints in Taulman’s T-Glase. That’s actual PET, but with composite chemicals to make it tougher, i think it’s not flexible enough depending on what hardness your springs should have.
As last i could offer Taulman’s Bridge Nylon, this is somewhat flexible and really tough (in terms of force required to break this material, not in terms of stiffness), you’d have a hard time breaking it, therefore it won’t snap when high forces are apllied, while T-Glase could more likely break.
I am trying to get my hands on some other Nylon materials, but for this purpose they are fairly similar.
Take a look at taulman3d.com and colorfabb.com for the data sheets.
What size should the spring have? I do not only offer printing but also CAD services so i could design any spring you want, aswell as parts that allow easy mounting of the spring, for example a base cylinder that the spring is printed on with custom screw holes or similar.
Beside that my printer features dual extrusion, if you want the spring to have a helix shape (cylindrical) then you have to get this made with support material, which my printer can do.
Another material that you maybe concider is ABS, this however would only work if the spring does bend relatively less and doesn’t have to sustain high forces.
I do not offer Innoflex materials, but dependend on your order size i’ll buy Innoflex for your springs, the choise of colors is yours. The other materials are available in White, milky and clear optics, Colorfabb’s XT is available in 11 other colors, if you need those the same as for Innoflex applies.
Take a look at my hub, if you are interested:
https://www.3dhubs.com/siegen/hubs/marius
Hope to hear from you,
Marius
Een veer heb ik nog nooit gemaakt. Aan welke afmetingen denk je ?
Size of the spring: diameter 100mm, height +/- 50mm.
Our standard production material has hardness 50-55D, tensile modulus 185 MPa and tensle stress 11MPa @ 10% strain
How much turns?
It’s a specific design which I cannot disclose here. I first want to know if the material could be suitable for making a spring-like element
Ok then, i can provide you the following data about the materials that i recommended earlier:
Colorfabb’s XT:
http://colorfabb.com/files/amphora\_pds\_en.pdf
Nylon (different versions):
Bridge Nylon
Bridge Nylon
Nylon 618
http://taulman3d.com/nylon-618-spec.html
Nylon 645
Nylon 645 Spec
PET (T-Glase)
i am not that much into material sience so you’d have to decide wether or not those materials fit your needs.
I have XT, Bridge Nylon and T-Glase in stock but could order the other nylons upon request.
-Marius
I will have Taulman’s Alloy 910 in on Monday, and could print the spring for you. It’s the new “latest and greatest,” and should work great for springs.
Alloy 910’s MTL characteristics:
Tensile Strength = 8,100PSI
Modulus PSI = 72,932
Max Elongation at break = 31%
More on the material: http://3dprintingindustry.com/2015/03/22/taulman-unveils-strong-versatile-3d-printing-filament-alloy-910/
I can also order any filament that you may need.
If you want to give it a shot, shoot me an email
I will sign an NDA, if needed.
Hey Joseph, thanks for the input! Moving forward, can you please use a link to you Hub profile as means of contact? Cheers
Yeah, no problem!
I’m rather new to 3D Hubs, so I still have to get used to linking my hub.
https://www.3dhubs.com/detroit/hubs/3d-detroit
Welcome and happy printing :wink:
Hi !
I offer Semiflex by Ninjaflex which has a hardness of 50D. Since there is low demand for this material i buy it just for the specific customer, smaller amounts would be available in black and white. Larger amounts can be printed in black, red and blue.
Please contact me via my hub or email if you are interested.
marius.breuer@cad-breuer.de
-Marius
Hi !
I have not yet recieved a response regarding my last comment about material offer. Please answer to one of my comments whether you are interested in ordering such a part or not, i can also get my hands on materials with harness of 45D and 65D.
Marius
Thanks for your replies. I have found a solution nearby, but will keep your information at hand for possible future projects.
