May 2017
I need quotes for a large part using ABS material.
The approximate dimensions are 500mm x 180mm x 50mm
Let me know if your printer can make the part as one piece.
US only
    May '17
    May '17
  • 6
  • 747
  • 4
Hi Pattersondesign,
Your part would fit on my bed as one piece. My maximum print volume is 950 mm x 950 mm x 450 mm. I do not offer ABS as a material option but I think my PETG might work as an good ABS substitute. If you are open to considering PETG, check out my hub here: https://www.3dhubs.com/service/183766.
Alex
You can see a few examples on my hub page. Outside of 3DHubs, I also use this printer for prototyping marine parts.
