I need quotes for a large part using ABS material.
The approximate dimensions are 500mm x 180mm x 50mm
Let me know if your printer can make the part as one piece.
US only
created
May '17last reply
May '17- 6
like
US only
Hi Pattersondesign,
Your part would fit on my bed as one piece. My maximum print volume is 950 mm x 950 mm x 450 mm. I do not offer ABS as a material option but I think my PETG might work as an good ABS substitute. If you are open to considering PETG, check out my hub here: https://www.3dhubs.com/service/183766.
Alex
Yes, I am open to using the PETG. I will have a look at your hub. Thanks!
Man I thought my new printer was going to be pretty big at 300X300X450! What are you running?
I have a 3DP1000 made by 3D Platform. They are the only manufacturer of large format FDM printers that I have found.
Woah! Those are some big printers! Do you mind me asking what sort of things you print at those sizes?
You can see a few examples on my hub page. Outside of 3DHubs, I also use this printer for prototyping marine parts.
