Dec 2017
Could someone assist me in settings for my printer. First one I have had i am using a tronx which is a anet a8 clone. If someone wouldn’t mind that users slic3r take some screen shots of your settings for abs 1.75 .4 mm nosel I would appreciate it. Just need a base settings and I will be able to go from there. Thank you if you can help.
    Dec '17
    Dec '17
  • 3
  • 918
  • 4
Hi, personally I would start from:
speed: from 40 to 50 mm/s
hot end temp: about 225°C/230°C
bed temp: about 85°C/90°C
0.2mm layer hight
2 or 3 perimeters, 3 top and bottom layers
for ABS increase temperature by 5 degs.
but first, be sure the bed is leveled (level it 3 times after 3 times homing, and heated to print temp) and belts are tensioned.
