Hi All,
My XYZ Printing, da Vinci Mini 3D printer isn’t working right, It started when my filament roll came off the side, and the filament came out of the little nozzle it is supposed to be attached to.
I have tried re-attaching this to the nozzle, and it started up O.K, no warnings on the XYZMaker App I use.
Although it did print the guide-line, it still was kind of not right… It was all thin, and was swept away when the printer went to print the ‘i’ I requested it to build.
The ‘i’ didn’t print what-so-ever, so I decided to ask on this thread,
Please answer ASAP, and if you want any videos I will be happy to attach them.
:> Thanks!!!
It’s difficult to understand what happend, would you try to explain it again in other words? It kind of sounds like you need to adjust Z offset??? Attach or send video?
You might have a clogged extruder. If the filament came out then it could well have broke off, there could be debris in the extruder/hot end that’s affecting the flow of the Filament. You could have some poor filament as well, I’ve had bad quality stuff before that messed up my hot end and is completely useless.
