Dec 2016
Hello all. I just purchased a Formbot TRex2 3D printer. I have been working with it all week trying to learn how to use it. On my third print, I had a small, very uncomplicated job. I was simply trying to print a rectangle 3"W x 8"L x 3/16"H to serve as a floor for a building model that I had 3D hubs print for me earlier. The edges did not come out square. From a side view, the printer made the edges at about a 45 degree angle, though this was not in the model. Any Idea what could cause this? I was using PLA at 230 degC.
    Nov '16
    Dec '16
  • 16
  • 15.2k
  • 3
Can we get some better pictures, sorry but cant really see the edge. Did you tried to print a normal cube to see how the edges are look like for that?
Also please share the STL file also to check.
Regards,
Tamas
Hello Tamas, thanks for responding. Yes below are some better pictures of the corners. No I didn’t print a test cube, that might be a good thing to do huh? I have made some test prints that have come out very nice. This one in particular however needed square edges.
I attached the stl file that I made from Sketchup. I created the g-code from Cura. I guess I expected the machine to print square. I am using PLA at
230 degC and 50mm/sec, .0.2 Layer height. My bed is heated to 57 DegC.
tan_bldg_floor_1.stl 1 (684 Bytes)
Hi Frank!
The stl file looks fine, its just a simple rectangle no errors in it.
Was the print stick well to the print surface at all corners(bed leveling)? As this looks like the corners lifted /curled up during print and this caused the issue, so check the bed level again, and watch it during print if its lift up or not.
I would suggest to print a smaller test cube, to check how the printer prints walls.
Here is 20mm cube to test you can scale it up from 20mm to 40mm http://www.thingiverse.com/thing:1366547 79
Its a ringing test also so it will show mechanical resonance near the holes if there is any on your printer.
Here is also a good troubleshoot guide for print errors:
https://www.simplify3d.com/support/print-quality-troubleshooting/ 132
I would also lower the print temperature to 200-210C for PLA the 230 looks way too much. Bed can 70C and in Cura you can set it to print a brim(platform adhesion part, usually by default its print 20 lines around, in the expert setting reduce it to 6)
Regards,
Tamas
I can’t quite see exactly the problem with the edges from the pics. I do see is a ton of wobble and ringing artifacts. Usually that means belts are not right enough, the print head may not be secure enough, or something else is being allowed to move around when it shouldn’t. You can also try slowing down the acceleration to 300 and jerk to 1 and see if that helps.
If you are using Cura btw, you may have the “Make overhangs printable” option turned on which would round off edges.
Please read the original post once again. He just wanted print a rectangle shape plate for the house model witch was printed by somebody else already from 3D hubs(yes its quality quite poor but we are only interested on the current problem).
T.
Tamas, again thanks for your help. Yes I did see the base material adhered well, I don’t think that was the problem. I have since communicated with formbot. I was using the high temperature with the PLA because I was having trouble getting it to stick to the bed. Formbot directed me to move the nozzle closer to the bed. I did that and was able to lower the extruder temperature to 210 successfully last night. I’m already using the brim setting in Cura. I’ll try the test cube. Again thanks for your time and attention. I would like to work toward becoming a hub for 3D hubs.
Yes I made the model for the building, but didn’t do the print. I left the model without floors intending to make them myself. I purchased a formbot t-Rex 2 printer kit and tried to make one of the floors the other night. It will suffice for my model but I expected the edges to come out square.
was trying to find out how to fix that.
13 days later
Got your mail, I will make reply to you, and we will continue there.
Have a great day!
T.
