If you upgraded to Sailfish - that’s your problem. I did the same and it fried my board. Bottom line - Sailfish kills these machines.
I can’t agree with you. I have 4 machines without sailfish and get more instances of the “garbled lcd screen” on those vs 8 machines with sailfish. Unless I misunderstood you.
Have you checked the connections on the LCD or from LCD to PC board? I did not have this issue at all but sometimes things get loose from all the vibration that is going on as the printer is working. Once I had a loose extruder motor connector that was only coming loose while printing, jamming the filament inside and I thought it was just bad filament…
The printer did the garbled LCD even before upgrading to sailfish, constantly. Sometimes even with broken prints when it did it (maybe unrelated but seemes to correlate). Now it only garbles the screen but prints perfectly.
I’ll check
I’m not sure if I’m happy or sad to hear that it happens to non-Sailfish machines. My machine with original firmware works perfectly. The one with Sailfish died within 1 day of upgrade. Maybe it’s just a coincidence.
So, just for your knowledge. Original firmware, is Sailfish(ish). MBI pulled sailfish’s motion planner and other items into its firmware around 7.0 The only difference is the amount of maintenance that each has received. MBI firmware is long abandoned, Sailfish 7.7 is still maintained and has addressed many bugs, both trivial and the very serious ones that could lead to disaster. did you know that original firmware wont report higher then 260C on the extruder, even in a runaway heater situation. USB printing is never recommended.
To blame sailfish on borking your board is silly and pure non-sense, Not meaning any offense( and also not being involved with your installation or troubleshooting), but 99.99% of sailfish installation problems are user generated. Myself included, I failed to follow the directions and had issue with printing in the center.
The garbled screen is a pure and simple hardware issue, neither firmware will cause or prevent it. Sailfish allows you to deal with it, by pressing the right button. Wanhao has started to insulate the ribbon cable with some sort of shielding. I have posted pics of how I have dealt with it.
Done this to me too, all I do is press the left arrow key and it returns to normal
Hi I have a problem with this screen appearing half way thorough a print, however when my screen gets garbage, my X motor starts to grind very loudly. Would this also be do to interference?
Mine had Sailfish but doesn’t work with right button. Just with a restart, but a few minutes later it happens again.
Why did you take off the main board fan?
