Hi guys I have had my printer for about a month now and cannot get the print quality to improve. I have printed a temperature tower to try to fix the temp but it still doesn’t seem to be right. On every print I get oozing and stringiness. I have set the same settings on my partners cr10 with the same filament and his comes out perfect. Any help would be appreciated thank you. Pla 200° BED 60
Dsk001
I usually print pla from 190-200 without a heated bed. Pla usually doesn’t need the heated bed and since the davinci is an enclosed printer it gets really warm in there with the bed on. Also I have never got a temp tower to print as my davinci ignores temp changes when using simplify3d and I haven’t seen a option to change temp on their default software. If possible add a fan pointing toward the print to help with overhangs. Also the YouTube channel 3d print creator started with a davinci pro 1.0 and some of his older videos might give you some good tips I am forgetting. https://www.youtube.com/channel/UC\_vETXvgwBNRxhbJA0b5u6Q
