Apr 2017
Try is with the silver prusa filament and like wirlybird said, play with the temperature. Printing speed for a marlin should be around 20-30 mm/s :wink:
Do you print at normal speed? Try use another slice. In use cura with my prusa mk2
In my case i have live-adjusted the Z-axis (you can set this in the settings menu) to -0.300. That was a result of the test prints of calibrating the first Layer. It is well documented in the manual: http://www.prusa3d.com/downloads/manual/prusa3d\_manual\_mk2\_en.pdf
Chapter: 6.3.9.
After fine-tuning this “live z-axis” i got much better prints and the first layer is perfect.
Probably this helps for you, too?
Greetings,
;-liver
Hello, what speed did you use ? Have you try with Cura ? I have the same printer as you, in kit, and i had some issue with slicer, this is why i use Cura and the result are compliant with my expectations now. Z adjust is also -0.300 to get a good first layer. Let us know ! For economy silver PLA from Colorfabb (2.2kg) i put 213° for hot end and 60° for bed. ED
The live z adjust is dependant on each individual persons printer and the height of their PINDA probe, which is manually adjusted
Exactly!
I don’t know how many I have seen with damaged beds because someone said “set you live Z at xxx” or “you live Z needs to be at” and then they crash the nozzle into the bed.
Correct,
My PLA live z-adjust is at -0.615 mm. Which makes the first layer look perfectly fine.
I have done another print yesterday, I will upload the result in a few hours. I have reset all my changes in the printer profile and used the default setup. On top of that I have tensioned the belts a little more (Not sure if this had any effect). But the print came out much much better.
Pictures will follow soon as I probably need to tweak it some more!
He looks pretty good.
I would work on a .2 version and get that nailed first before fighting with .1!
Remember temps are going to be one of the big issues on Marvin so printing 2-4 at a time can help. Temp on yours doesn’t seem bad though. Speed may be a factor. I printed at about 20mm/sec but then heat can become a factor more.
I think the settings are close so small changes and one at a time to see the effects of the change.
Some of the problem areas are good on yours like the key chain ring.
I did not read through all the replies, but I am having the greatest success using the Prusa’s Slic3r version.
I used the recommend settings for the most part. For Marvin, just select detailed.
Also, on Printer: Settings → Mode – > High Power
Settings → SD Card → Normal
