Hi, I apologize for the corrupt English first.I have a Tronxy X5S 3d printer. And I bought a sensor( SN04-N NPN) to add autolevel property to the printer. I thought I would be able to get rid of the small curves on the hotbed. I’ve arranged my commands according to autolevel as follows. But when I want to print a large shape, the extruder remains in the air at some points of the hotbed, print properly at some points, and at some points worth the hotbed(no filament output). So the autolevel property is not working properly. Can you help me? What am I doing wrong?
My Marlin Configrution.h Changes
#define AUTO_BED_LEVELING_BILINEAR
#define X_PROBE_OFFSET_FROM_EXTRUDER -40 // X offset: -left +right [of the nozzle]
#define Y_PROBE_OFFSET_FROM_EXTRUDER 20 // Y offset: -front +behind [the nozzle]
#define Z_PROBE_OFFSET_FROM_EXTRUDER 0.5 // Z offset: -below +above [the nozzle]
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0.6
#define X_MAX_POS X_BED_SIZE
#define Y_MAX_POS Y_BED_SIZE
#define Z_MAX_POS 410
#define GRID_MAX_POINTS_X 7
#define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X
//Set the boundaries for probing (where the probe can reach).
#define LEFT_PROBE_BED_POSITION (20)
#define RIGHT_PROBE_BED_POSITION (280)
#define FRONT_PROBE_BED_POSITION (40)
#define BACK_PROBE_BED_POSITION (320)
My Repetier Host/CuraEngine Gcode Changes
G21
G90
M82
M107
G92 Z0
G1 Z5
G28
G29
G28 X0 Y0
G28 Z0
G1 Z15.0 F9000
G92 E0
G1 F200 E3
G92 E0
G1 F9000
{IF_BED}M190 S{BED}
{IF_EXT0}M109 T0 S{TEMP0}
You also need to turn on
FIX_MOUNTED_PROBE
Z_SAFE_HOMING
I believe that you should have
#define Z_MIN_POS 0
