SOC3D
3
I use a rubber mallet and a paint scraper (scrapper?)
I have had this problem with parts that have a lot of surface area. My printer has no heated bed to heat up and loosen the part, so I used a heat gun (a hair dryer would work also and would probably be much safer) to the bottom of the print bed (glass). Just enough to make the top of the glass almost uncomfortable to touch. Then I use a paint scraper as others have suggested. Be careful and try to keep the heating even on the glass since unevenly heated glass can crack.
When I tried a paint scraper and brute force, I have damaged the bottom edge of the part. Not to mention the force involved could alter the level on your print bed or damage other things.
SOC3D
5
Agreed, my mallet and paint scraper vs glass and plastic causes a lot of damage. I just replace glass and reprint parts when it happens. A good sized rubber mallet makes up for any parts loss in time savings for me though. Recently I’ve been removing the beds of parts to let them cool and swapping to another build plate so there is little interruption in print time.
Scrapper, but be very careful! I chipped my bed when a print too well.
Most the time you have to let it cool down completely before you try to pull the print off. You should hear popping when the print is cool enough.
If you can, get under one corner of the print (doesnt have to be much), then use floss to slide under that space. Run the floss through the entire print until it comes off. (Better when the bed is cold)
Lol thanks, it works like a charm and your print gets a hint of minty goodness
knabo
11
For ABS you normally hear a pop as the plate cools, so far I have not had any problem removing from a cool plate. I print on glass with glue and I have found if I use too much glue it sticks very hard. My favorite spatula for removing prints is: http://amzn.to/1WpHlwb
For PLA you don’t get the nice pop. Instead, I heat the bed to 80 degrees and this loosens the print enough to get the spatula under. Just be careful not to deform the print, the PLA will be soft.
n23d
12
I use a scraper with a single edged razor blade in it.Works best on a cold build plate. Start at a corner. I have wondered if using a can of air for dusting keyboards could be used to cool the bed below room temp to get a release. Never had to try it just a thought.
I use very thin feeler gauges to slide under the print. I then slide progressively larger ones under the same corner until the Gap is big enough to fit my plastic spatula and pray up on it.
SOC3D
14
I’m proud to be the only one who uses a hammer on prints
SOC3D
16
Just use this, I was skeptic at first but it turns out to be an excellent tool because the edges have a varying thickness:
http://shop.turtlecreations.nl/3DPrinters/3DPrinterAccesoires/buildtak\_spatula
Oooooh.
