Agreed, my mallet and paint scraper vs glass and plastic causes a lot of damage. I just replace glass and reprint parts when it happens. A good sized rubber mallet makes up for any parts loss in time savings for me though. Recently I’ve been removing the beds of parts to let them cool and swapping to another build plate so there is little interruption in print time.
Scrapper, but be very careful! I chipped my bed when a print too well.
Most the time you have to let it cool down completely before you try to pull the print off. You should hear popping when the print is cool enough.
If you can, get under one corner of the print (doesnt have to be much), then use floss to slide under that space. Run the floss through the entire print until it comes off. (Better when the bed is cold)
That’s a good idea!
Lol thanks, it works like a charm and your print gets a hint of minty goodness
For ABS you normally hear a pop as the plate cools, so far I have not had any problem removing from a cool plate. I print on glass with glue and I have found if I use too much glue it sticks very hard. My favorite spatula for removing prints is: http://amzn.to/1WpHlwb
For PLA you don’t get the nice pop. Instead, I heat the bed to 80 degrees and this loosens the print enough to get the spatula under. Just be careful not to deform the print, the PLA will be soft.
I use a scraper with a single edged razor blade in it.Works best on a cold build plate. Start at a corner. I have wondered if using a can of air for dusting keyboards could be used to cool the bed below room temp to get a release. Never had to try it just a thought.
I use very thin feeler gauges to slide under the print. I then slide progressively larger ones under the same corner until the Gap is big enough to fit my plastic spatula and pray up on it.
I’m proud to be the only one who uses a hammer on prints :slight_smile:
Lol mallet or hammer?
Just use this, I was skeptic at first but it turns out to be an excellent tool because the edges have a varying thickness:
http://shop.turtlecreations.nl/3DPrinters/3DPrinterAccesoires/buildtak\_spatula
It didn’t end well.
Oooooh.
Also a good idea and the Buildtak might be an upgrade. Of course you could go grab some glass to hold you over and also order some Buildtak.
i use multiple single edge razor blades, make sure the bed and part are cold, or else you will warp the edges/corners, start a razor blade in each corner and gently tap them around the print to loosen it. Usually it will just pop off, if it still doesnt, i take the handle of a screw driver and tap it (with some force) on each side till it pops off. I do this all the time, cause i would rather my completed print be difficult to remove, than it coming loose halfway through a 12 hour print and having a pile of filament laying there.
