Jan 2015
Right, after the amazing response I got to my question about a glass bed, I’ll ask the other thing on my mind.
I picked up a 50mm fan at Maplins and printed this: Flashforge creator 50mm fan mount by davinci85 - Thingiverse 10. It clips on and off as necessary, quite a good fit, falls off sometimes.
But I’m powering is separately via an external power adapter for 12v. Is this the best solution?
I use Simplify3D, and part of the advanced options seems to control the fan speed. Is this the main print head fans, or an additional?
Best solutions for PLA cooling fan please.
Cris.
    Jan '15
    Jan '15
  • 5
  • 2.1k
  • 4
It depends on the motherboard. If the controller is already wired to control a cooling fan, like the FlashForge Creator Pro, then it’s an easy matter to hook it up. That’s idea, because then it’s under software control so you can have your slicer control the fan, so it can be on for PLA prints and off for ABS prints. There’s no particular risk to doing this. Watch the video that 3DAmigos printed, and if that looks scary to you, don’t do it. To me, it looked like 15 minutes work - the hardest part is running the wiring up the guide tube!
For other controllers, such as the Makerbot Replicator, the controller board could drive a fan, but you have to solder a chip to the board, so that’s more work (and risk of damaging the controller). Some controllers don’t have any capability to control a fan, in which case your only option is to power it externally.
