I was wondering if I can renew the filament spool since I am printing big scale objects with oyr deltaWasp 4070. So when I see the filament is about to finish, pauase and replace with a new one?
YES! In the menu there is a “pause to filament” function. You just select it, the printer will raise the head and retract all the filament. Load the new filament and prime the nozzle and then press the menu button and the print should restart. I always try to be as gentle on the head as possible and not move it so there is no visible print lines from the change. Sometimes there just is, sometimes not. Hope that helps!
Hello Asya, yes you have the option to “pause for filament” the Delta WASP will automatically retract the filament. You will then need to load the filament manually as always. Just click on the knob and you will see your options.
You can do it this way, but it is a bit overkill in my opinion. Getting use of the resurrection function is great, but there is an easier way for sure.
