Mfg Date: 2010
S/N: 7149
Background info:
The Alaris 30 is a predecessor to the current Stratasys Objet 30/24, Prime, and Pro line of printers. It has the same form-factor and uses the same ‘VeroWhite 830/835’ and ‘Support 705’ material. This printer has always been under a service contract, and has been very well maintained. It was most recently serviced in December. It’s currently at a commercial address.
If you’d like to see a test print, I can coordinate a time for you to visit our facility.
Looking for $6,500 OBO – serious offers only.
Approximate dimensions: 45" W x 30" D x 35"H
With the stand, the height is about 50"
Weight: 250lbs
Total machine time: 2,969 hours
Last full maintenance was in December 2017.
Specifications:
Tray Size (X,Y,Z) 11.81 x 7.87 x 5.9 in
Net Print Size 11.57 x 7.22 x 5.9 in
Layer Thickness 0.0011 in
Accuracy 0.0039-0.0078 in
Resolution 600 x 600 x 900 dpi
Materials VeroWhite FullCure830 modeling material
FullCure705 gel like support material
Cartridge Weight 2.2 lb
# of Cartridges: 2
# of Print Heads: 2
Machine Size: 32.28 x 24.4 x 23.22 in
Machine Weight: 183 lb
Operational Environment Temperature: 64-77 F
Relative Humidity 30-70 %
Electrical 110 -120 V Single P, 50-60 Hz 7 A or 220-240 V 50/60Hz, 3.5A.
