Apr 2019
It could be your printers internal hard drive. Is the printer itself still producing noise? Does it still Idle or is it completely silent? You could try hooking up a monitor to the back of your printer (near the power off switch) via a VGA cable and see if you can get to the windows backdrop of the internal computer.
I tried connecting to a screen via VGA, but it does not produce any image. also, when turning on the machine there is only the fan from the power supply.
My gut feeling now is a faulty power supply, as rmigliac suggests. I will try with a voltmeter, or contact my local objet support to request a new power supply.
Do you have a local computer repair shop? Bring your hard drive and get a new power supply. This happened to me last year. Cost me €100 to fix. At least they could eliminate it if it’s not the problem and it hasn’t cost you too much?
I
I tried with a multimeter, and it seems as if there is no power coming out of the PSU (see attached image). I also tried to check the current on the cable in top left corner of the internal pc (“to PC board”). No current there either.
Am I right in saying that the PSU is faulty? Question then is, how to take out the PSU. I tried opening up the front panel on the objet (next to print material drawer), to see how the PSU is connected to the stratasys board. A daunting sight to say the least. Are there any tutorials out there? or schematics of the cables at least?
Still, i would rather spend days detaching all the cables instead of paying 5000€ ++ for someone else to do the same job.
Sounds like the PSU is dead but to make sure, check the voltage (120/240) going into the PSU. If its present, then check for fuses on the power supply itself. If those are good, then its a good bet that the PSU is faulty. Perhaps you can order one and replace it yourself?
