I think you will find it particularly difficult to dissolve PLA in acetone, I only know of one modified-PLA brand that is even affected by it in the short term. But ABS should generally work. The only thing to consider is that soaking the part in acetone could leave you with the entire part coated in ABS slurry, but you could just keep enough fresh acetone around to rinse that off afterwards.
Thanks Jonas, You’re right… I can see the slurry abs to be a bit of a problem. I didn’t know pla is acetone resistant. Thanks for letting me know that. I think i might give the abs a go next week with some simple prints and see how’s that gonna turn out
PVA is optimal around 190C-210C with bed plate at 80C. Also degrades around 200C, which makes it incompatible with Nylon. Carbon Fiber Nylon is optimal at 240C-260C with bed temp about 120C. HIPS is optimal at 230C-240C with bed temp about 115C which makes it more suitable for Carbon Fiber Nylon. HIPS 12 is soluble in Limonene 31.
