I need help! I got a busted up Nobel 1.0a with missing parts. I fixed all the broken parts (cover, resin tray, laser carriage belt spring tensioner), Because of the damage in shipping almost a whole bottle of resin leaked all over the printer. Inside and outside. It took me most of a day to clean it. It is missing the Power supply, software and cleaning tank. I need the specs on the power supply to see if this rescue will power up. Can someone look on their AC power supply and tell me what I need to buy?
Also I have seen other posts about emptying a new XYZ resin bottle and filling it with Makerjuice. What Makerjuice can be used from the settings from the bottle, which begs another question of which XYZ resin bottle to buy?
Since my printer is not up and running I want to run this by everyone on how you MAY be able to use Makerjuice without wasting the expensive XYZ resin.
1. Buy a new bottle of XYZ resin but do not connect it to the auto filling tubes.
2. Adjust the resin level switch so that the software thinks the resin tray is always full.
3. Visually watch your resin level and add it accordingly.
What do you think?
Thanks.
