It was just for loading the pla the first time from abs. We couldn’t get the extruder hot enough with the pla cartridge to extrude the abs through properly. After the initial loading of pla everything was fine we could switch from pla to pla with no issues. Sorry I should have clarified it was only on the initial switch from abs to pla.
I just flashed mine. I’m using Chuck Hellebyche settings from YouTube and tweaking as I go. If you Google search you can find many set ups. Voltivo and solid forum have lots of info. Google abs or pla with repetier and DaVinci. It won’t nessicarily get you perfect prints everything but then neither does xyz.
I just flashed mine. I’m using Chuck Hellebyche settings from YouTube and tweaking as I go. If you Google search you can find many set ups. Voltivo and solid forum have lots of info. Google abs or pla with repetier and DaVinci. It won’t nessicarily get you perfect prints everytime but then neither does xyz.
Has anyone replaced their hotends with a chimera? Any instructions? Comments? Concerns?
I can’t agree with cbrown35. I have been using XYZPrinting’s 3d printers for more than a year with thousands of printing hours. Right now I have 4 da Vinci 1.0 running at least 12 hours/day. This is a reliable printer, with good quality, extremely easy to use and the best cost vs. benefit. Something I don’t like is the proprietary filament. I have also 2 rep rap prusa that I built myself, 1 Robox, 2 ZMorph3D, 2 M3D, 1 Makerbot2x and used a lot Ultimaker 2 and for hi end services I have used Fortus 400 … So I know very well the qualities’differences between FDM 3D printers. The quality of da Vinci series is very good for a USD 500 printer for ABS and PLA. Similar quality of printing i Makerbot wich doesn’t pay your money back. Hi end 3d Printers such
as ZMorph
and UltimaKer have better resolution… but you’ll pay 4 or 5 times more… I do… as I have some printings with PVA/HIPS support. Regarding the PLA bad of use, that’s necessary to calibrate the bed and unclog the nozzle (after select clean nozzle option at Utilities). Then unload and load again. Try to change the filament cartridge.
I have a friend that owns a robo3d and he doesn’t like it so he built a rerap printer and he said it works better
On build quality and having a professional look to it even the xyz crapware. Out of the box for $500 USD + shipping you can’t go wrong. I’ve used pruisa kits, reprap, ultimaker, objet and even a fancy $2,000,000 stratsys that will print metal powder at 20microns! On initial out of the gate get you going xyz is hands down the best unit I’ve found for price and ease of learning curve. Did I like proprietary cartridges in only 4 remaining colours? Heck no! Do I like that if you have a problem you have to send your machine back to xyz for service? Heck no!!! 180days warrentee?!?! WTF Do I love that there is a following of didicater tinkers and hackers that have embraced this little (or not so little) 3D printer and made software that enhances the well build design and positive aspects of the machine? HECK YEAH!!! Do the flash make the mods and if your still upset with your $500 printer sell it on eBay and buy yourself a $2000 kit that you have to assemble yourself and tinker with for months before you can even get a decent print out of the thing.
This is a common problem with a lot of low end printers. The extruder is really designed for one or the other. I had a Makerbot which recommended PLA but could only manage ABS. When getting my current printer (davinci 1.0) I looked specifically for ABS, I wouldn’t trust putting PLA though it. By rule of thumb, if it has a heated build plate it’s for ABS and if it doesn’t it’s for PLA. More expensive printers I don’t think have this problem (but I’ve not tried)
Can I ask you about the XYZ printer software hacked , so i can download it from somewhere. Thank a lot.
David
