This is my first foray into 3-D printing and I would appreciate some insight on if there is any way to make my model design better in any way. After many unsuccessful attempts and wasting a couple hundred dollars trying to replicate and hollow my original hand-made clay design using silicone and resin casting, I am kind of at the end of my rope for patience. I have decided to try out 3-D printing as recommended by a friend as I need the piece to be hollow and clear to translucent, and preferably resin based. However, I am clearly not very familiar with many of the materials that can be used, the methods for printing, and etcetera. I have ordered two test pieces so far, and am waiting to get the results using two types of resin; formlabs clear resin and another that just said clear UV cured resin. However, since I am going to be getting about 8 of these designs, I want to ensure I am using the best type of material for what I need structure and finish wise, as well as cost-wise. I am willing to put time into the sanding and buff and polish of the exterior to give it a nice glossy finish, but the interior needs to be hollow so that it will be lightweight, and also use less material and be cheaper. This piece also needs to be clear to cloudy-translucent as I will be shining a LED through it to give it a glow. Because the interior is glowing, it does not matter to me if the hollow interior is rough on the inside, as that should help diffuse the light, but the exterior I will want to make smooth. If I can’t sand the object due to the printed material, I would like to add a thin layer of clear epoxy if it is chemically possible. The model is not going to be supporting anything and have any pressures on it save for its own weight so structurally, I do not think it will need to much “infill” in the walls at all. I have seen that my model can also be printed in translucent or transparent plastic as well. Any suggestions or recommendation on that or other materials that I may not have considered? Thank you for your assistance, and as a last note, If it helps with your suggestions, I am really trying to get these piece printed less than $20 each, as I’m going to be needing around 24 different pieces. Feel free to modify my model if you have any physical suggestions that would improve it. hornf.stl 1 (18.9 MB)
