I´m having this issue where I´m trying to unload the filament, but I get this grinding noise from the extruder (not the hot end but the gears that push or pull the filament), while the filament is firmly stuck.
Upon inspection, I noticed that the temperature first increases, reaching 186°C, but instead of the gears starting to pull at this temperature, the nozzle starts to cool down.
Afterwards, at 107°C the gears start pulling on the filament, but obviously at this temperature it´ll stay stuck to the nozzle.
Seems to me like a coding issue, as the printer instead of pulling the filament at the highest temperature, it skips the operation an pulls when temeprature reaches its minimum…
What printer are you using?
Hi Christian,
Please let us know what printer you are working with, so I can make sure your post is appropriately forwarded to all the right people that might be able to offer you some assistance.
Thank you.
Best,
Benny
