I am an authorized reseller of the Raise3D N-Series 3D Printers.
I have in stock the N1-Standard (Single Extruder) and the N1-Dual printers.
I am awaiting arrival of my 2nd wave of N2 and N2 Plus hopefully next week, the 1st wave was so out in 2 days.
These printers are of the latest versions and include the V2 Hot Ends.
Actually, I find idealMaker a much better slicer than Simplified 3D.
With idealMaker you have full control of all functions such as speeds, flow rates, pauses, cooling levels, etc. and it already comes loaded with profiles but you can add your own of course, and ideaMaker will fix you models in a way the NetFabb does, if your model is too large there is a split function so that you can split your model into smaller parts and just print each part separately - how many slicers do that?
idealMaker creates supports and rafts that come off like butter.
There really is no need for Simplified 3D on the Raise3D N-Series, I only use Simplified 3D for my Ultimaker 2 now.
For those of you who are waiting on your Raise3D printers you are all going to be amazed by the print quality and the ease of removal supports using the idealMaker software.
The ideaMaker software gets updated with new enhancements regularly. I suspect that manual support will be coming soon.
These machines without a doubt the best of the best right now, with their 7" touch color display, complete file storage system, 4 USB ports, you can use either USB Stick, SD Card, Ethernet or wi-fi that actually works - so much for Zortrax with is promised but cancelled wi-fi.
These printers have replaced my Zortrax printers as my go to printers.
I still sell the Zortrax M200 but when my customers see how the software works and the printed results from both they usually choose the Raise3D.
They are better designed, built like tanks and are just a much printer better not to mention open sourced, you can use any brand of filaments.
You don’t usually require a raft unless you have many supports on the bottom.
These printers come with a heated build platform with a glass plate with BuildTak, however I prefer using PEI clipped on the glass, just my preference.
I could go on and on but I think you get the drift.
If any Hub would like me to print a free small file just email me your .STL file as an attachment to sales@petermake3d.com and I will print it and mail it to you for free. If you would rather not send me a file but just want a sample then just request a sample print from us.
I will leave any raft, brim or supports on the model so you could remove them yourself.
Peter of PeterMake 3D
