AKBAM
Hi All,
Just joined and of course my first print is little ole Marvin, he was printed on a DWS 020X, at 25microns using ABS001 resin at 100% normal size.
Not the best pictures as I am stll learning how to take images of models - especially white material ones which are difficult to show the detail.
As with all prints on DWS - surfaces are all smooth, no layer lines.
Kind regards
Andy
Impressive quality, @Jack_Hu! Thanks for sharing your Marvin with us.
One of the smoothest I’v ever seen! @derKarsten can you add this to our hall of fame
Hi Andy, thats very cute! What’s a DWS? Resin printer? Yes other colours are much easier to photograph. I’ve noticed that…
AKBAM
@jandj3d - for DWS look here - http://dwssystems.com
regards
andy
Thanks! That looks… a bit pricey
Hey Andy,m what made you choose a DWS printer and a Formlabs, for example? Any particular advantages for this one?
AKBAM
8
I had a Form 1, had it replaced twice due to faults (the support team were excellent though) and ended up with a Form 1+, printer was OK - but never managed to get consistent prints, especially larger ones, also the surface quality was not brilliant - still layer lines even at 25micron. But for the the price a fantastic printer - especially now with their expanded range of resins and their preform software is very good in my view shame it does not export stl…
I then sold the Form 1+ on the strength of DWS releasing their prosumer XFAB at beginning of this year following their announcement at CES, alas that particular printer is plagued with delays (also I believe the resin cartridges will work out ridiculously expensive)- irrespective of what they announce in the press I believe this will not be available in 2015!
So I decided to look around - and happened to be given the opportunity to purchase an DWS 020X. Anyone who has held a print and seen the amazing surface quality will know what I mean - its as good as if not better than envisiontec printers!
Also DWS offer an extensive range of resins - which ultimately helped me make the decision to buy.
Using the DWS is easy - DWS have two software apps- one to generate supports and create the build (Nauta) and the other Fictor is used to control the machine.
Overall I wanted excellent surface quality,high accuracy and a proven range of resins - DWS offer this and the print size on the 020X is a very acceptable at 130x130x90mm - but you do pay for this and the resins are not cheap.
Regards
Andy
Thanks for the great insights, Andy! Much appreciated!
hi I am looking to buy a SLA printer and am stuck between Formlabs Form 2 and DWS X-Fab. Could you tell me something about the DWS printer?
