I bought one of the refurb maker select v2 printers that are being sold on ebay .This was supposed to be professionally factory refub but judging from what I’ve discovered it is far from it . I was pretty excited to finally receive it only to find a bent base and a busted switch . The end plates and switch aren’t an overly big deal and are easily replaceable if the seller is willing to send replacement parts . I figured I’d see what else may be wrong and decided to give it a shot .The bed and the extruder heated up no problem at first but then it turned out the nozzle was jammed . After getting the crap out of the nozzle, it no longer heats the bed or nozzle . I click the quick setting for pla and on the main screen it only shows the desired temps and not showing the heat rise as it did before . If i go to extruder it says extruder 1 off , it seems there is nothing that I can do to turn it on . All the connections seem fine but no heat anywhere . Chances are that I’ll just pack this thing up a send it back right away but if I’m missing something simple with the heat then I may be able to work with the seller to get this thing proper . At this point it’s a real drag cause this was a Christmas gift to myself .
