So i am fresh out of teh box with my new monoprice mini v2. followed the instruction and the cat print seemed to print perfect.
I then decided to take my own stl files and give one a go. I inserted my own sdcard with the two attached stl files, let the printer warm up and selected print. But when i select any of my stl files and hit print, nothing happens. i get a pause and a cancel button both work, but even pausing and starting doesn’t make it print. the extruder just goes down to the plate and sits there and does nothing.
I am in a similar boat, I put my stl file through Cura, had it sliced, saved to the correct removable disc. Plugged into the printer, pre-heated, and pressed print after selecting the gcode file. On Cura it said 5 hrs 7 mins, there is a blue bar that almost filled up all the way, 2 hrs later and the nozzle is still in the same place. What gives?
