Apr 2015
i use PLA only and i extrude at 175… 180 for for first layer…
settings are now showing up as pics… will do some better pics shortly
Some better pics… the white marlin is an old one i had in my scrap box… it shows the problem more clearly… i even included a photo of the advanced marvin found on thingiverse… that one came out as it should thou not as detailed as shown on thingiverse but that is due to my printers capabilities (which is not good enough)
the black marvin is almost the same settings… except the extra suck that ruined the hook
Can you explain what exactly the “such”-feature does?
it “sucks” back the filament…
it can also be called retraction… not sure why kisslicer uses that wording
Does it only pull back the filament or does it also push out the same length at the end of a “retraction”-move ? On such a small print it should not compensate oozing by using extra restart distance (that means that you pull 2mm in and push for example 1,8mm out to compensate 0,2mm oozing in the nozzle). The extra restart distance in this example would be -0,2mm because 2,0mm + extra restart distance (-0,2mm) = 1,8mm
Please look up the settings and adjust the settings so that the printer does not compensate oozing. Did you adjust the extrusion length (if possible for your printer) ?
Watch this video for explanation:
-Marius
it has seperate settings for retraction and prime… and yes on such a small print its not needed and can end in a catastrophy
i trimmed the settings and its now working as it should
watching the video now…
By extrusion length you mean the steps pr mm for the extruder right? Yes i got that one spot on :smiley:
btw… if there are some terms you cant explain well in english but better in german give it a go, i can read german no problem, its more my spoken german and written that are not good
Did you make another print with those settings ? Another thing that might help and is pretty obvious is that you need a clean nozzle, if yours is full of filament blobs etc. heat it up to ~150°C (depending on filament) and brush the extruder with a brass brush. I usually clean the nozzle and heater block while it is heating for the next printjob. Depending on the extruder you have you should be very carefull and use a soft brass brush, however this wouldnt clean up as fast
yep i printed with those settings and have not had any issues since…
about the nozzle… yep i clean mine too, its easy to spot if blobs has formed… i just use a small nail scissor and gently scrape from from top to bottom where filament comes out… in many cases i aim to do this at 150 where all the filament comes off in one ball of “goo”
