Apr 2017
I did it !! Marvin 50 micron. What did I change to succeed? Basically three items:
  1. Infill set to 10% rectilinear. This way there is much less material, so less heat inside.
  2. A small 2mm brim helps to keep Marvin glued to the heatbed.
  3. Disable Z hop when retracting filament, this helps to avoid some hairy finishes.
