Jun 2016
This happens if there are faces turned the wrong way or holes or overlaps in your model. Very common if you use a rotating extrusion tool or circular array tool in your software and any part of the path shape crosses the center axis. It can be really hard to find to a software that detects and repairs it is your best bet.
Thanks for the help everyone! It was a result of trying to save the file as multiple surface bodies from SolidWorks. Converting to a solid first fixed the problem.
