hi
i need to replace Makerbot Replicator 2 Extruder it really bad and its always breakdown , is there away to replace it with different Extruder .
Thanks
What’s the problem? clug? skipping? what’s the error code?
I doubt you can replace it with a different type. You can replace the extruder tip by itself and also the heater block, and extruder.
Have you thought about upgrading the nozzles and the internal guide tubes? Will require a little work on your side but it is a viable option.
