Feb 2015
21 days later
1 month later
Still looking for advice?
After several month of bad SmartExtruders and horrable Firmware - the MakerBoth 5th Gen. is now ready to print in a high quality and without clogged SmartExtruders.
Comparable with the 4th Generation of MakerBot devices.
Yes, I am still looking for advice! Thanks for the update.
It is great you finally have it working correctly. I am starting a small project and need a reliable double extruder printer. Plus, I am designer and tinkering is definitely not my thing. Flashforge was my second option but some people say it is a good machine once you get it to work, pretty much like a Makerbot.
I think the MakerBot Replicator 2x is a reallyl great machine. The name of the device is experimental because of the ABS Filament you have to use.
If you made your first experiences with the 2x and the ABS filament you can get high quality prints out of it. You can also print PLA with the 2x but unfortunately you do not have the goody of the active cooling nozzle!
5 months later
1 month later
I’ve had a fifth gen since they came out. The smart extruder design is terrible and it malfunctions constantly. I’ve looked at every teardown and rebuilt mine dozens of times so I know the design is fatally flawed. Also, I do not understand why anyone would retract filament, the melted portion will probably break when you retract it and be left somewhere in the filament path which means your extruder us now useless unless you know how to rebuild them and it’s not easy. If you want to change filament snip it and run it through and simply run the next one in. Never retract filament.
I had a heater short which burned the heater circuit which is located on the carriage circuit board not inside the smart extruder. Makerbot insisted that I ship the entire printer which would cost more than its probably worth since I live in Canada.
Maybe some quality 3rd party parts will be forthcoming, everything is have looked at online is junk and garbage. Cheap crap even worse than makerbot.
1 year later
To be honest, I dont know what all the fuss is about. I have a Makerbot 5th Gen and I just purchased a Makerbot Mini, and I think they are great machines. Sure I have had an occasional issue with them, but I think you would be hard pressed to find the “Perfect Maintenance Free” Machine. The extent of the issues I have faced are a few clogs no and again, but nothing I wasnt able to fix in about 5 mins max. The removable extruder makes it a breeze to pop off, clear a jam and put it back on without missing a beat. I have recently upgraded to the Smart extruder + for both machines, and I havent had a jam yet! I think with a little time and attention, some TLC, your Makerbot can provide you with many many hours of printing with no trouble.
