Hello all! I am new to 3D printing and recently bought a second hand maker select v2. When I assembled it I noticed screws missing. Specifically on each Lower end motor on the vertical piece. I believe this is causing one of the rods that it is attached to come undone.
Is there a web site I can go to buy these screws?
Another issue im having is with the home setting. The bed pushes back to the end and does not stop cashing the unit to jerk back and forth.
Attached are some some pictures of the issues. Thanks!!
Screws should be available at most hardware stores. M3 or M4.
On the other issue it could be a bad limit switch or cable.
Thank you! Is this the same for the leveling screws on the bed?
Probably. You could always take the leveling screws out and get something that fits and just do all of them if you can’t get an exact replacement.
I go on 'Amazon and by bolt kits for the M3 and M4 screws. Search for this:
https://www.amazon.com/Glarks-170Pcs-Stainless-Button-Assortment/dp/B01J7NM9LI/ref=sr\_1\_1?ie=UTF8&qid=1485988502&sr=8-1&keywords=glarks+170pcs
I buy these kits of bolts since printers use a bunch of these in the different sizes.
Also handy for print projects to bolt together.
