My M200 has stopped extruding. I replaced the hotend and the nozzle thinking there might be an obstruction, but that didn’t help. I cleaned the motor in the extruder from plastic and bits but that didn’t help either. That little cog on the extruder is turning, but it’s not forcing the filament through. If I apply a little pressure when guiding the filament through it nozzle does extrude like it should, however, the second I stop applying pressure to feeding the filament, all extrusion stops.
Hi, is the thermocoupler assembled correct? Sounds like the material is slightly too cold to extrude properly. If you remove the extruder motor and heat the extruder, it should be possible to feed the material quite easily. Would try this first. Regards Olli
Agreed, can almost guarantee the extruder ribbon cable needs to be replaced. After you replace it, print this to help prevent the failure from recurring.
I’ve been having a same problems over the last few days. I replace the nozzle, clean the old one with acetone, cleaned out the extruder motor with the brush very well, and then I unplugged the extruder cable and made sure that it was plugged in all the way in correctly and securely. After that didn’t work I moved a clip attached to the wire and the tube that the filament goes through about two or 3 inches above the extruders so that the cable wasn’t lying flat and it started extruding so maybe try that. good luck!
Hey buddy, you tried looking at your motor output? You might have burned it out. If not, try soaking your extruder tip in a solution as per the guide on zortrax.com 1
Edit: please ignore, I didn’t see all the replies. When you cleaned the extruder, did you remove the motor? Beside the extruder gear/cog there is a very small bearing. The filament should go between the gear and that bearing. Check if the small bearing is still in place. Also, cut the end of the filament (15cm), then check the diameter of the “new” end.
