Jan 2017
My M200 has stopped extruding. I replaced the hotend and the nozzle thinking there might be an obstruction, but that didn’t help. I cleaned the motor in the extruder from plastic and bits but that didn’t help either. That little cog on the extruder is turning, but it’s not forcing the filament through. If I apply a little pressure when guiding the filament through it nozzle does extrude like it should, however, the second I stop applying pressure to feeding the filament, all extrusion stops.
Any idea on this?
    Jan '17
    Jan '17
  • 13
  • 2.6k
  • 10
Hi, is the thermocoupler assembled correct? Sounds like the material is slightly too cold to extrude properly. If you remove the extruder motor and heat the extruder, it should be possible to feed the material quite easily. Would try this first. Regards Olli
Better to check if the Extruder motor is working fine first.
try doing this:
1. Remove the nozzle and load the filament and see if the filament comes out.
2. Check if the Extruder motor is rotating clockwise
Do you chack it out, that the extruder motor are moving without material? For example if you load a new Filament.
So you check taht the extruder motor are work, if not it’s possible that the cable has a problem.
I hope it was helpfully for you.
Bg
daniel
Edit: please ignore, I didn’t see all the replies. When you cleaned the extruder, did you remove the motor? Beside the extruder gear/cog there is a very small bearing. The filament should go between the gear and that bearing. Check if the small bearing is still in place. Also, cut the end of the filament (15cm), then check the diameter of the “new” end.
