May 2016
Hi there. I’m trying to find someone who can help me fix a clear acrylic bourgie lamp which has two broken spindles that hold the lampshade on. They are around 10cm long. I have one intact spindle to work from. I’m in bath and would appreciate meeting someone face to face so I can bring the spindle if you think you can help. Many thanks! Polly
Unfortunately I’m not on the same continent. I want to say thank you for adding scale to that photograph as it helps a lot to determine the best way to reproduce the model. I would cast that part in a crystal clear or water clear urathane vs printing in order to keep the clean look.
That’s really helpful thank you for the advice. Hopefully I can find a 3D hub nearby.
