I need a relatively simple part drawn. 7" diameter circle, 5/8" thick with a 6 on 5" bolt pattern. the pattern needs to be counter sunk 3/8" deep. the center has a 4" diameter hole that goes all the way through. that part I can draw, the part im unable to is adding threads so that two of the plates can screw together ( one side male, on side female). anyone able to help me out please ??
Hi there !
I’m a hobby designer and would be glad to design this part for you.
Just follow the link below to get to my hub, there you can start an enquiry by clicking on “contact this hub”. I’ll set up an order for you, once the enquiry is made.
This is a fairly simple part, so I’ll be able to construct that for a few bucks :wink:
Marius Breuer
contacted. thanks
Will be happy to help you out, it won’t take 5 mins to model these parts so will do it FREE of charge.
Just follow the Designeering link below to get to my hub and start an enquiry.
As Jeff already said as a response to my comment, the project is being completed with my hub at this moment.
