Nov 2017
My name is Floris Koopmans, I do the marketing for Zeelander Yachts.
At our company, we will soon we will be releasing a new yacht model and we would like to let our owners know in a creataive way that it’s coming.
As a gift we would like to send them three miniature yacht models of our existing yacht range. I would like to know what the possibilities would be in 3D printing.
3x30 models would have to be printed in 20cm, 25cm and 30cm. That would make a total of 90 miniature models. I was wondering what possibilities there are in materials, what level of detail we would be able to achieve and what the price of a batch like this would cost.
We obviously have 3D drawings of each yacht but I assume they are not 3D print ready. I would need someone to do this for us.
Looking forward to discuss further.
kind regards,
Floris Koopmans
    Nov '17
    Nov '17
  • 8
  • 1.7k
  • 7
Hi Floris!
You have come to the right place! That is something many hubs could help you with…including mine (https://www.3dhubs.com/service/3drapidprints). You can also search for a hub yourself (not all hubs monitor Talk). Click the red “Start Manufacturing” button at the top right of the screen. Upload any old file (even if it is unrelated to your project), scroll down and choose a common material like PLA, click “manually select a hub”, and browse the endless list of hubs for one that you think will fit the job. When you find one, click the hub name, then click “view hub”, then click “contact” and describe your project.
Good luck!
Hey Floris, Edward hier.
Je herinnert me misschien nog ik had meegeholpen met de belichting samen met leon van jullie yachts en de last minute montage van je video presentatie.
Ik heb zelf zo’n 5 jaar ervaring met 3d printen en het maken en aanpassen van cad modelen voor 3d printen.
Ik help je graag met het uitwerken van de printbare schaal modellen. En de juiste print technieken te selecteren.
Je kan me bereiken op: 0618438032
Bel me even om een afspraak te maken om de details verder te bespreken.
Vriendelijke groetjes, Edward
Hi Floris. If this project is taking place in the south Florida branch, I’d be happy to talk more about your project, and I have worked with other marine companies in the past (that’s what we do in FTL). If this is happening in the Europe branch, would recommend searching for someone local by doing a custom search for 3D modeling services, as some modeling will most likely be needed in addition to 3D printing. Best of luck!
Goedemiddag Floris,
Er zijn veel verschillende 3D print technieken, elk met hun eigen voor- en nadelen.
Zonder een idee te hebben van het model dat je wilt laten printen is het niet goed mogelijk om vooraf al een idee van de kosten te geven. Kosten zijn
vooral afhankelijk van gekozen 3D print-techniek, materiaal en vooral volume.
Bedenk echter ook dat 3D printen niet bepaald de snelste productietechniek is. Op mijn Hub pagina (https://www.3dhubs.com/service/55629 1) staat een foto van een 34 cm lange maquette die ik onlangs in opdracht heb geprint. De printduur daarvan bedroeg 64 uur.
Dat gezegd hebben zijn er bij de keuze voor FDM-techniek meerdere materialen geschikt. Meest gebruikt is PLA, maar ook een materiaal als NGEN zou een keuze kunnen zijn. Met FDM 3D printen is de resolutie ongeveer 0.5 tot 1.0 mm, afhankelijk van de richting (X-Y of Z-as). Echter dient daarbij bij voorkeur rekening gehouden te worden met het minimaliseren van overhangs (overbruggingen). omdat die de printkwaliteit negatief kunnen beïnvloeden.
Zonder in details te kunnen gaan zal je model hoogstwaarschijnlijk in meerdere delen geprint moeten worden.
Voor verdere vragen kun je me uiteraard altijd contacten via mijn Hub.
Met vr. groet,
Maarten van Maanen
Hoi Floris.
Ik denk dat veel al gezegd is in de reactie’s die hier al staan. Onze hub heeft een Stacker S2 ter beschikking die perfect is voor deze klus. Met deze printer kunnen wij uw onderdeel printen zonder op te splitsen. Daarnaast heeft onze printer de mogelijkheid om 2 dezelfde prints tegelijk te printen, wat de kosten tot meer dan 1/3 kan beperken tegenover hubs die ze stuk per stuk moeten printen.
Wij hebben daarnaast veel ervaring met onze materialen en kunnen zeker tot de juiste oplossing komen. Aarzel niet mij te contacteren moest u interesse hebben of er nog resterende vragen zouden zijn. Dit kan het best via mijn Hub (https://www.3dhubs.com/service/andreas).
Met vriendelijke groet,
Andreas
Dear Floris,
I can help you with large models > 30 cm.
I have a 40cm printer and one 1m printer.
Besides, I am a sailor of catamarans.
Best regards, Maxim
Goedemiddag Floris,
Bij deze toch nog even de vraag of je inmiddels iemand hebt kunnen vinden om je te helpen.
Maarten van Maanen
TypeR
