Sep 2018
If you want to be added to the list of people offering services in Germany, please comment here. Include if you are able to do 3D modeling, what materials and technology you are able to print in, as well as any colors/finishes you can offer.
    Sep '18
    Jan '19
  • 12
  • 5.1k
  • 7
I offer the following
printer: Jgaurora A5 with 0.4 mm nozzle
technology: fdm printing
size: 300mm x 300mm x 320mm
resolution: 0.1 - 0.3mm
material1: PLA( black, while, drk blue, green, red, brown, orange, yellow, purple, pink, gold, silver, transparent)
material2: PETG( black, gray, dark blue,transparent blue, red)
material3: TPU( black, white, dark blue, yellow)
pickup, shipping accepted
time to print order: 1-2 days
or order at: 3d.dbcons.de 40
@MaddieG
How will interested people reach us? There will be no hub profile, etc. as of Octobre 1st. Will there be any possibility to get in contact?
das interessiert 3dhubs offensichtlich nicht mehr ! Ich hoffe das jemand diese “Lücke” schließt, aber es wird schon eine Grund haben warum 3dhubs das nicht mehr machen möchte. Zu viel support für zu wenig umsatz, schätze ich.
Split this topic on Sep 17, '18
A post was merged into an existing topic: Switch to Fulfilled by 3D Hubs announcement
15 days later
I offer the following services in Bochum, NRW:
  • CAD, prototyping, design-to-print, and custom prints with internally reinforce.
  • 3D model fixing, alteration.
  • Printer: DIY delta machine
    Type: FDM/FFF, Delta construction, Single extrusion.
    Print size: D300mm x 400mm
    Accuracy: < 1.5°; < 1.5% (position error) or +/- 0.3mm (X/Y) and -0/+0.15 bed adheation +/- 1/2 layer height (FDM/FFF error) depend on which is greater.
    Material stocked: PLA (Gray, White, Dark Blue, Red). Other materials/colours available with lead times.
    Nozzle size: 0.25; 0.3; 0.4; 0.5; 0.6; 0.8mm (Also on upcoming machine(s))
Shipping, pickup, deposit to Package stations.
Coming soon:
  • Printer 2:
    Type: FDM/FFF, Cartesian, Dual extrusion/Colour mixing.
    Print size: 200mm x 200mm x 260mm
    Accuracy: (Prevision) < 0.5°; < 0.3%; 0.01mm position error or (FDM/FFF) specific. To be measured.
  • Printer 3:
    Type: FDM/FFF, Cartesian, Dual extrusion. Highspeed.
    Print size: 230mm x 230mm x 260mm
    Accuracy: (Prevision) < 0.3°; < 0.3%; 0.0125mm position error or (FDM/FFF) specific. To be measured.
  • CNC router:
    Type: Moving gantry.
    X/Y/Z size: 500mm x 700mm x 50mm (up to Z= 90mm is available with lead time)
    Accuracy: (Prevision) < 0.1°; < 0.1%; 0.0025mm position error. To be measured.
    Bit: up to 8mm (TBD)
    Materials: Plastics, Composites, Non-ferrous metals and alloys. No fibre reinforced.
20 days later
We offer the following:
Printers: Form2, Ultimaker and Prusa i3 MK2S and MM (farm)
Modelling: yes
Casting with resins and epoxy: yes
Small batch production: yes
Overnight production: yes
Post processing services: polishing, removing support structures high quality surface finishes
Technologies: FDM, SLA
Materials: Various bioplastics with almost all colors also glow colors, Copper, Brass, Wood, TPU, standard resins, polypropylene simulator, semi-flexible
Deliver: same day, pickup, dhl, hermes, ups, ups express 12:00
Deliver time: usually less than 2 days (not business days) for black and white orders, other colors and quantities needs to be checked before
Packaging: hassle free, environment sensitive
Contact: manufacturing@3r.gmbh (Please send your data with requirements)
Location: Hoppegarten bei Berlin, Endhaltestelle U5 Hönow (HEP Einkaufspassagen)
2 months later
Du schreibst hier einfach jemanden an der dir zusagt (per persönlicher Nachricht) und dann geht alles seinen Gang.
Beste Grüße,
Jörg
Hallo, bin aus NRW Gütersloh und hier sind meine Drucker:
MakerBot Replicator 2
Druck Volumen: 285x153x155 mm
Layer Höhe: 0,1 - 0,3 mm
Druckformate: .stl, .obj, .Thing
Druckferfahren: FDM / FFF
Druckmaterial: PLA, Flex, PETG, TPU, …………
Farben: diverse einfach nachfragen
MakerBot Replicator 2X
Druck Volumen: 246x163x155 mm
Druckformate: .stl, .obj, .thing
Druckmaterial: ABS
MakerBot Z18
Druck Volumen: 305x305x457 mm
Druckformate: MakerBot (.makerbot), STL (.stl), SolidWorks (.sldprt, .sldasm), InventorOBJ (.ipt, .iam), IGES (.iges, .igs), STEP AP203/214 (.step, .stp), CATIA (.CATPart, .CATProduct), Wavefront Object (.obj), Unigraphics/NX (.prt), Solid Edge (.par, .asm), ProE/Creo (.prt, .prt., .asm, .asm.), VRML (.wrl), Parasolid (.x_t, .x_b)
Druckmaterial: PLA
Zortrax M200
Druck Volumen: 200x200x185 mm
Druckferfahren: LPD
Druckmaterial: Z-ABS, Z-ULTRA, Z-HIPS
‎Abholung, Versand Weltweit akzeptiert‎
‎Zeit, um die Bestellung zu drucken: 1-2 Tage‎
‎Bestellen können Sie bei‎ info@one3druck.de
Ich warte auf Eure Anfragen!!!
Hallo zusammen,
hat eigentlich hier schon jemand mal einen Auftrag bekommen???
Hallo Frank, eine gute Frage. Ich bin nur im Forum um Probleme am Drücker zu lösen. Ich weiß auch nicht wie man hier starten kann. Gruß Jens
hallo MaddieG,
kannst du hier Aufträge vermitteln??? oder wie kommt man welche???
