OK, I have looked and looked at this, and looked again at this. I do not see how it is possible unless your glass is not level!
I know that is not too helpful, but I thought that if I at least replied, your message would get bumped so others can agree or disagree.
Sorry but I looked at this also and it’s not making any sense to me.
I also think this problem is weird. This issue happened after a abnormal printing: Talk Manufacturing | Hubs 17 can find the detailed description here). I am wondering if it’s caused by the abnormal work of stepper motor or motor driver module (A4988).
Have you ever met this issue?
This is normal for a delta printer that isn’t well set up. You need to ensure that:
1) All towers are parallel (use a digital caliper’s depth guage to measure this, get all 6 measurements to within 0.1mm)
2) All towers are at exactly 90 degrees to the bed.
Once you’ve done this, use this calculator to put in the remaining fudge factors into your firmware.
http://escher3d.com/pages/wizards/wizarddelta.php 21
It’s a massive pain in the bum, however if you want to print flat with a delta you can’t cut corners.
Thank you for your reply. I recheck the towers and I can guarantee that they are parallel and nearly 90 degrees. Actually, this printer printed well a few days after I finished building it, but it suddenly printed abnormally in one model-printing process (detail:Talk Manufacturing | Hubs 9). And then this issue surfaces. I can’t find the cause of this issue. Do you know what may cause this?
“OK, I have looked and looked at this, and looked again at this. I do not see how it is possible unless your glass is not level!” I too had a problem with this and found out that my glass bed wasn’t level. I kept telling a friend of mine that I believe the glass was warped and he didn’t think so until the glass bed cracked in half. I have replaced the bed with a metal (thicker) bed. It made a huge difference.
if you are describing the bowl/dome effect youll need to adjust the the deltaradius
