MSURyan
A few days ago I purchased the Anycubic Kossel XL Delta printer. It came with all the required parts and I assembled it in a few hours. The trouble began when trying to install the driver. Every time I try to install the driver from the SD card it fails. Also, whenever I try to print a file, the head toes directly over the x motor (Off of the heat bed) and extrudes at least 3 grams of PLA that doesn’t land on the bed. Then the head rises to about 100 mm above the bed and attempts to print the object in thin air. It will continue to move and extrude plastic in air unless I stop the print myself. I have used the auto-level feature multiple times. During the auto-level feature, the head comes down and touches the bed at multiple points and then says “Anycubic Completed” and returns to a normal position. I have also tried downloading Arduino, and Merlin, and Pronterface. None of these seem to be able to run properly on my PC and/or connect to the printer itself. I am at a total loss. Please help.
