Jul 2016
Szia Adám!
Had the same issue with a rostock and the problem was that one arm was longer. But first check the bed with a aluminum ruler and a lamp ( put ruler’s blade on the glass, light it from behind if you see any light coming through, you can purchase a new glass, the bed must be at print temperature(60-70C) for this!!!
If your glass is fine, luckily as its a delta printer every parameter can be modified:
http://www.thingiverse.com/thing:745523 20
So just follow the instructions with printing the calibration test and the measurements will identity the problem. If one of your arm differs from the other 2 (so to that direction its prints longer or shorter) in a Marlin FW with the instructions provided you can correct the towers.
It worked great for me.
Regards,
Tamas
Are these gaps always on the same spot? i had a lot of problems with bed leveling and installed better endstops. Now it works perfect.
Regards,
Eddie
Hi all!
Again thanks for all the valuable input. I’ll try your suggestions, probably this weekend (weekdays I’m quite busy unfortunately). I’ll get back to this thread after that, with my findings!
Adam
I use OpenDACT, which is an automated process if you have a z probe or FSR. http://forum.seemecnc.com/viewtopic.php?t=8698 3
OpenDACT uses repetier EEPROM data and tweaks it as it calibrates. I calibrated my bed flat to about 0.02-0.01
Save your current EEPROM and clear out all data except the approximate diag rod and etc.
Just calculate your steps per mm with prusa’s belt calculator and lock the steps per mm correction by putting 0.0 steps per mm correction.
17 days later
Hi all!
Sorry for not responding for so long, I still haven’t had time to actually try the solutions you offered. I’ll definitely get back to this thread when I can find time to experiment, life has been keeping me busy these past weeks.
Again, thank you!
Adam
Hi all!
Long time, but…I tried printing the calibration object, for delta printers, but unfortunately Slic3r seems to screw up the slicing…I used kisslicer before, but that refused to put the object in the center of the print bed…*sigh* Slic3r seems to under extrude, although I have given it the correct data regarding the printer. I never had this issue with kisslicer. As a matter of fact the extruder nozzle was clogged twice in a row (for two calibration objects) when the print got to the part where it was supposed to add the “stubs” (or blocks , in the instructions) at the top…I tried increasing the extrusion rate, but it didn’t help. It seems to pull back way too much (destring I presume) , but just with those stubs, and then extrude way too little, resulting in an airgap inside the extruder, which in turn leads to a pla “blob” forming and clogging up the thing…I probably should’ve bought a plug and print machine…
Adam
9 months later
dear all i have a similar kind of problem we just builded our kossel xl 3d printer but it has a problem on planarity, the printing is somehow “spherical”! if we start to print it is 3mm high on the centre and then once you move around it start to touch the bed, like if it is not worling on a flat space but slightly spherical… did you ever had this problem?
Just scroll down an please read my other post there is a link how to calibrate a delta, in your case the the firmware’s delta radius needs to corrected first in the firmware.
thank you tpalagyi sorry i can’t find it, down here?
21 days later
Hi guys,
Just a quick update…I pretty much gave up on this printer unfortunately. I simply don’t have the time/patience to fight with this (honestly piece of shit) bed. I’d need a proper manual leveling system (three screws with springs), to have a chance. M666 sort of does…something…but it seems unpredictable, sometimes it changes nothing, sometimes it does…There is a probe on the head but that never really worked…3d printed parts for a 3d printer…from what I’ve sen so far is a bad idea. I wanted to get into 3d printing relatively cheap but that didn’t work out. If I ever go for another printer it will be a plug and play type for sure. I do love fiddling and tinkering, but this is just pure frustration !! I tried so many methods, and the results are simply unpredictable. I’m really disappointed. That’s just 700 dollars of junk sitting on my table…A very expensive learning experience for sure. I know some will simply say I didn’t try hard enough but…honestly I don’t want to at this point… Thank you for all your input! At least they probably helped others with a similar issue and a LOT more patience!
