I have been having a repeated issue with my Kossel (that otherwise works just fine): when I print a model that is high enough, at a height of exactly 5cm, the print starts failing: I hear a few subtle and intermittent licking noises, and from there on the layers are very poor quality and do not adhere to each other.
It seems like I am losing/skipping steps at Z=5cm, whichs messes a layer or two completely, and then all upper layers are not good.
Picture below, you can clearly the layer where things went sideways. I ruled out a problem in the G-code, this happens on pretty much all models I tried that are high enough to cross this 5cm value.
I inspected the rails, no mechanical issue, and anyway the kossel being a delta printer, a mechanical issue on one axis would not give a problem at a very precise Z height.
I put two failed prints of two completely different objects side by side, and the problem occurs within the same millimeter on both, i.e. at Z~5cm
I’m puzzled as to what can be the root cause of this ? What elements could possibly explain an issue that would repeatably occur at a given height ?
Thanks,
created
Jul '18last reply
Sep '18- 2
- 2.4k
links
