Sep 2017
Why this project?
We need your help to construct all models ready, this takes a lot of time and is also very costly.
Why should I support the project?
Be the first to receive the files. Some files will be downloadable later in the shop but not all. The packages will be more expensive than here, so save them now and save up to 40%.
My project shows ships for the different periods /ages. These can be printed on the scales for the different figure sizes from 6 mm to 30 mm (the larger scales could also require larger print areas).
The models are high quality and highly detailed. You can all models print with ABS or PLA.
more different ships can you find on KS:
https://www.kickstarter.com/projects/eslo/3d-printable-ships-and-accessories-stl-files 2
