On a DELTA printer, a layer shift due to a motor skipping steps or cutting out will make the print shift away from a particular tower. When it skips a step its usually trying to move up, or if it cuts out for a millisecond the carriage will drop down slightly. Both of these actions result in one axis being a few steps below where it should be, which in turn pushes the platform AWAY from that tower.
If your layers are shifting like your photo shows, have look which direction the part has shifted (maybe take a photo from directly above). This should point to which tower has the problem.
Ive done this many times to ensure bed calibration is right on. I even have buttons setup in Pronterface for X,Y,Z,Center Position locations. Always fine tune until a piece of paper just barely scrapes the head
I was actually considering trying this out a few times but unsure of the feature. I may give a go tonight on something I know fails to see how it goes.
Hey, first check to make sure all belts and pulleys are tight. Als make sure the print has isn’t wobbling then if that fails u may need to adjust the current to the stepper drivers
A shift like that is typically caused by the bed moving because parts are attached to it and being hit by the head. Secure the bed as best possible and use the zlift feature as previously mentioned. My kossel mini prints multiple objects like a champ, my only issue is stringing which I can’t eliminate.
My Glass bed is secured down and cannot shift side to side as I have tabs fixed to the 2020 fram with rads exactly matching the diameter of the glass bed. There is no play. I never have a problem with stringing unless I am printing in flexible filament. My printer has good days where it prints great and mediocre days where it prints soso. I have been into this now for about 5 weeks and had to do a lot of research and reading up to get it this far. It is a DIY kit that had no firmware when I got it. If I can get past this one last obstacle I’ll hopefully be fine
It definitely sounds like your move speed is too high (not your actual printing speed, but the speed for moving between parts) and/or your motor acceleration values are too high in firmware. To test lower acceleration speeds without having to reflash your firmware, go to control -> motion -> scroll down until you see acceleration and lower to 2000. Than scroll down further and change each of the individual motor (x, y, z) acceleration values down to 7000. Start there and see if it is improved.
