HI all
I would like to ask if wood filaments are similar to pla ? or they need a special kind of extruder to work with ?
i have a 3d printer that only works with pla should i try using wood filament ?
thank u in advance
Xeno
While woodfill print just like regular PLA, you need a bigger nozzle then 0.4mm, most use 0.8mm, otherwise it clogs very fast.
also never leave the woodfiil heated without printing, otherwise it will also burn end clog your nozzle
