So started up the FFCP and started the leveling sequence to prepare for printing a test file from the SD card. The leveling paper will not pass under the extruders at the center position even with the screw all of the way out. Has anyone else had this happen? Thanks,
Jim
Ive configured all of my machines to run the left extruder slightly lower than the right… Which ever is your lowest nozzle should be your default. Unless you plan to run dual extrusion all of the time, your better off with one nozzle lower than the other.
Or level off both extruders and pull one of the nozzles off when single printing. This allows for less than perfect settings on larger flat parts.
Are you sure you are screwing it to the right side? Because actually you should screw “in” to lower the bed. I had this misunderstanding the first time I was leveling a 3D Printer bed.
