Aug 2015
Den Haag, ALL3D krijgt vandaag Carbon Fiber binnen voor de Mark One, ALL3D 3D Print Carbon fiber HAAK! Minder dan 31 gram, trekkracht test min.175kg!
hallow, den haag hub peepz
De max trekkracht kunnen wij niet uit testen , we hebben niet de apparaten ervoor.
De haak hebben we ophangen.en gewichten eraan gehangen meer dan 750 kg hadden we niet.
Hebben jullie een idee om uit te testen?
Prakash Kanhai
ALL3D
Den Haag
more info visit our hub ALL3D
136.37mm x 69.57mm x 11.79mm
14.30cm3 nylon
11.87cm3 carbon fiber
infill triangle 100%
    Aug '15
    Sep '15
  • 4
  • 956
  • 3
ALL3D info over de mark One
the mark one can fabricate in PLA, Nylon, Fiberglass, Kevlar, and Carbon Fiber. With their patented unique Continuous Fiber Filament Fabrication technology, this is a printer capable of creating end-use parts as strong as steel.
Fiber-Reinforced Composites
What is a composite?
(From Wikipedia) “Composite materials are materials made from two or more constituent materials with significantly different physical or chemical properties, that when combined, produce a material with characteristics different from the individual components.”
What’s the difference between a thermoset and a thermoplastic
Thermoset materials (e.g. two-part epoxy) solidify during curing, which is an irreversible chemical reaction. Once cured, they cannot be melted. In contrast, thermoplastics can be re-melted and are typically tougher.
If you don’t use an epoxy (thermosets), how does Composite Filament Fabrication (CFF) work?
We developed a thermoplastic blend specifically formulated for good adhesion to carbon fiber and our FFF nylon blend. It’s non-toxic, and doesn’t require post curing.
What kind of reinforcing fibers can I print with?
The Mark One™ is capable of printing carbon fiber, glass fiber and Kevlar®.
How do composites printed on the Mark One compare to those built with traditional methods?
Parts printed on the Mark One™ can be designed to be stronger than 6061-T6 aluminum by weight and up to 1/3 the strength of the best carbon fiber composites made today. Performance data was collected from 3-point bend testing on an Instron® universal testing machine in the preferred fiber orientation
This document and it’s research are from markforged. We at ALL3D make use of the 3D Printer Mark One and materials we mentioned above. If you are searching for strong high-end ready to use printed parts check us out on ALL3D hub.
if you printed this hook end on what weight would the layers separate at?
it would also be good to see some tensile lab tests conducted, so yield, UTL, elongation, etc. (in 3 different directions across layers, with the layers, and diagonal.)
Hey @Luca_Marconi,
Misschien kan je een soort hefboom maken. Hierdoor heb je minder gewicht nodig.
Het is maar een idee. Ik denk wel dat het kan werken !
Zie hier mijn paint skillz
28 days later
SomeOne??? to test pencil load some tensile lab tests conducted, so yield, UTL, elongation, etc. (in 3 different directions across layers, with the layers, and diagonal.)
